- 2/3” 5M,3.45um Pixel, SmartSens CMOS Sensor
- MIPI CSI-2 Interface,2lane,4lane mode
- Mono 8,Mono 10,Mono 12 Data Format
- Manual exposure mode
- Video streaming mode, Trigger mode
- Hardware and Software trigger source
- Support trigger delay, trigger count function
- Strobe synchronization
- ROI
- Flexible frame rate settings
- Support Sensor Direct Access mode
Thechnical Detail
Technical Details | |
Sensor Type | CMOS |
Shutter Mode | Global Shutter |
Sensor | SC535HGS-MC3AN00 |
Color | MONO |
Image Size | 2/3” |
Unit Cell Size | 3.45um (H)*3.45um(V) |
Resolution | Maximum: 2464(H) × 2064(V)Typical: 2448(H) × 2048(V) |
Max Frame Rate | 4lane@8bit mode:2448 x 2048 @100fps4lane@10bit mode:2448 x 2048 @82fps
4lane@12bit mode:2448 x 2048 @70fps 2lane@8bit mode:2448 x 2048 @53fps 2lane@10bit mode:2448 x 2048 @43fps 2lane@12bit mode:2448 x 2048 @36fps |
Gain | Analog Gain(HCG included):1x to 48x(0dB-37.8dB)Digital Gain: 1x to31.9x (0dB-30dB) |
Exposure Time | ≤ 1/(max frame rate) |
Shutter Mode | Manual Exposure,Manual Gain |
ADC Resolution | 12 bit |
Pixel Format | Mono8,Mono10,Mono12 |
ROI | Support |
Mirror Image | Mirror and Flip |
Working Mode | Hardware Trigger,Software Trigger,Video streaming mode |
Trigger Mode | Trigger INPUT |
Strobe Mode | Strobe Output |
Electrical characteristics | |
Data Interface | MIPI CSI-2Data Rate / lane:1188Mbps
lane num:2 lane / 4 lane |
Communication Interface | I2C 3.3V |
Digital IO | Non-isolation IO:1 Trigger in,1 Strobe output,3.3V Level |
Power Supply | 3.3V DC |
Power Consumption | TBD |
Structure | |
Size | Length * width * height = 29*29*7.9mm |
Lens Mount | C-MOUNT01 ,S-MOUNT01 or M12 holder |
Operating Conditions | |
Temperature | Operating temperature:-30℃~ 60℃ |
Humidity | Humidity 95% or less |
Sensor | Spectral Sensitivity |
SC535HGS-MC3AN00 |
Document
Board Dimension
